pls, how to measure the tools on gang lathe ?
Results 1 to 11 of 11
Thread: pls, how to measure the tools on gang lathe ?
    Member deadlykitten's Avatar
    Jun 2015
    Antarctica
    Default pls, how to measure the tools on gang lathe ?
    hello, we have a citizen L12 : i don't like the procedure for measuring tools, which involves contact between cutting edge and material
    please, is there another way ? fast, reliable ? kindly
    we are merely at the start of " Internet of Things / Industrial Revolution 4.0 " era : a mix of AI, plastics, human estrangement, powerful non-state actors ...
    Jun 2015
    Antarctica
    Default Re: pls, how to measure the tools on gang lathe ?
    hi cosmo we also thought of something like this, but it is still slow
    we are preparing a setup ( od, id and live tools ), and the part cycle is pretty long; changing the tool also takes a while
    after we change the tool, we need to run 2-3 parts to adjust the offset, and this simply takes too long; too loooong
    i was told about an U shape thing, that allows fast repetition when changing drills, but this setup is done outside the machine, and after that the tool is put inside the machine
    it still takes too long
    i need something like a renishaw, etc, so to minimize the setup time
    maybe i need to consider quick change tooling not a fancy thing, but a must / kindly
    Jun 2015
    Antarctica
    hy hfjbuis, pls, would you share a photo ?
    hy z369, thx 4 the reply ...
    i thought of tapping a thread @ the end of the od tools, and put a screw in there ... kindly
    Jun 2015
    Antarctica
    thx hfjbus
    Jun 2015
    Antarctica
    thx hfjbus
    Jun 2015
    Antarctica
    hello colby thx for the reply
    i know about sandvick qs from a while ago, i also have a few ideas about some alternatives, but i need to postpone them time is time ...
    i don't use GOTOs, because it takes too much time to edit the program inside each operation, tool number is parameterized; if i wish to jump a specific operation, i simply put '-' in front of the variable that represents the tool
    it is the same thing in the end, only that it is achieved with less keystrokes
    also if each operation is inside a soubroutine, and i wish to jump over 3 operations, then i simply put '-' on 3 consecutive lines; like this, i don't scroll through the program
    less editing time = less setup time = faster trials
    also, oh god, i hate the citizen interface; i can't connect to the cnc through a local network, and i don't like running with the usb to the machine, and back to the pc / kindly
