pls check also attached image : green only shows that the cnc is moving; it may be fast, it may be slow, it may be running a warm-up program all day long
same, the blue zones from the images from the Citizen screen are not saying too much ...
is all about active cnc state monitoring, with a frequency high enough to spot ' particular cases '
there are situations when an interruption appears, and the operator may fix it without reporting it; maybe that situation could be prevented
