- Citizen M1-20 gang live spindle frequency drive problems
Hi Everyone,
I purchased a used frequency drive (Mitsubishi FR-Z024-0.4K) after my existing one shorted out. I soon realized that the used unit do not come off an M20 because it would not respond to any MDI commands. After initializing all of the parameters, I can now get the spindle to rotate, but only at a very slow rpm(10hz) regardless of what if put in MDI.
So I figure I needed factory parameters set by Citizen. Unfortunately, the list they gave is for a newer unit and the parameters do not directly match one another.
Anyone have the correct parameter setting for this unit?
Any help would be great appreciated.
Pete
- You may not post replies
- You may not edit your posts
Forum Rules
