Citizen L20 reloading parameter help
Results 1 to 3 of 3
Thread: Citizen L20 reloading parameter help
    Jun 2014
    Default Citizen L20 reloading parameter help
    Just purchased a citien l20 1995 an had to reload parameters, im having some problems/questions over this procedure,
    - when i put the dip pin 2 back to off, and start the machine, it stays in the cincom L presentation screen
    - i cant see how to change from $1 to $2 to load some parameters, the hard key doesnt respond,
    - in the PLC-SW parameter list in page 1 i cant seem to edit the lines,and it doent show any words, just the lock simbols next to each #
    This is the first time reloading parameters on a machine, please help, thank you
    Member MCImes's Avatar
    Sep 2011
    Default Re: Citizen L20 reloading parameter help
    I dont have experience with L's that old, but Ill take a whack at it anyways.
    1. I dont know
    2. On newer citizens (2001 model) there is only 1 set of parameters, not independent main/sub parameters like on a Fanuc. There is just "Input" or "output" parameters, no option for main/sub. Are you sure there is in fact an independent "Sub Parameters"?
    3. To modify the PLC data, (on our machines) you have to go to MAINT -> I/F DIAG, then type "1001" (first box on the left) and "M" into mode (the 3rd box from the left). Press input. Nothing will happen, but you can now change the PLC data.
    (4.) Ask your local distributor. You're most likely to get reliable information from a maintenance tech who's been around a while.
    Good Luck!
    CNC Product Manager / Training Consultant
    Jul 2015
    Hi Colox,
    Did you fix your CITIZEN L20 1995?
