Please help me calculate stepper motors.
Results 1 to 8 of 8
Thread: Please help me calculate stepper motors.
    Aug 2012
    Denmark
    Default Please help me calculate stepper motors.
    I have a CNCRouterparts PRO 4"x8" from 2014. It has been unused for a few years, and when I wanted to start using it again my PC was broken so I do not have the original MACH3 settings.
    I then upgraded to UCCNC software and AXBB-E motion controller. I've got it all running but I can’t figure out how to calculate my stepper motors. And right now my brain is burning from messing with it all day.
    I found this calculation from cncrouter parts https://www.avidcnc.com/pro-rack-and...-34-p-226.html I hope it is the same specifications on the 2014 model. and I have a DQ860MA drive which is currently set to 1600 micro steps. But I do not mind if it is changed.
    in fact I would greatly appreciate if you have any suggestions for the best settings!
    Could someone please help me figure out what to write in UCCNC to get it up and running?
    Also I am from Denmark so I do everything in mm not in inches.
    Jan 2016
    Default Re: Please help me calculate stepper motors.
    Can you pull the hard drive from the old PC and install it in another PC or external HD case so you can access the mach3 directory? If so all the settings you used would be available to you.
    Aug 2012
    Denmark
    Quote Originally Posted by Steve303 View Post
    No it’s all gone.
    Aug 2012
    Denmark
    Anyone!
    Apr 2010
    Quote Originally Posted by Gunni View Post
    Anyone!
    The attached file (mach3 profile) will get you started. The site does not allow xml files, so I have renamed it to TXT.
    Attached Files Attached Files
    Aug 2012
    Denmark
    Thanks but I do not have mach 3. is there no one at all who will help me along the way?
  7. #7
    Member koenbro's Avatar
    Jan 2016
    Wish I could help. I also have a CNC router parts set up but use Mach4. Have you thought of calling up Avid/ CNC Router Parts and asking them?
    Sent from my iPhone using Tapatalk Pro
    Avid CNCPro4824, Warp ESS, Nema 23 steppers, Delta VFD, 2.2kW spindle
    Hypertherm Powermax 45XP with TMC3in1 THC
  8. #8
    Apr 2010
    What specifically is needed? Steps per unit? Velocity/acceleration?
