Those Chinese sensors are pretty reliable. They don't usually go bad unless you do something to kill them (like shorting the output).
Does the red LED on the sensor light up when you put a piece of metal near it?
Are you measuring "continuity" with the sensor powered up and connected to the breakout board? That would not give you any meaningful results because there are voltages present in the circuit.
