Where to BUY End Mills for a Spindle
Results 1 to 10 of 10
Thread: Where to BUY End Mills for a Spindle
    Member RNGPRODUCTS's Avatar
    Nov 2019
    Default Where to BUY End Mills for a Spindle
    Finally got my Avid PRO 48x48 up and running. I have the 2.2kw spindle with ER20 Collets.
    I come from a metal machining background. Where is everyone getting Carbide End Mills?
    Some of these CNC ROUTER specific bits are way overpriced compared to traditional end mills.
    Any insight?
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: Where to BUY End Mills for a Spindle
    End mills and router bits have different geometries, for cutting different materials.
    I usually use Onsrud, Vortex, or Amana. No, they are not cheap.
    UCCNC 2017 Screenset
    Feb 2005
    I get carbide and HSS from Toolstoday.com. I have had alot of great outcomes with the single flute HSS tools, inexpensive and sharp as hell. All the HSS tools are more forgiving of mistakes as they are more flexible then the carbide tools.
    Member handlewanker's Avatar
    Sep 2006
    If you go on UTUBE and browse the vids by Stefan Gottenswinter he advocates 3 flute carbide end mills and runs them dry because he like to not have the muck to clean up afterwards.
    For example, he did a test run in steel on a manual mill and ran an 8mm 4 flute carbide roughing end mill at 6mm depth of cut, full width, with a feed rate of 90 mm per min without coolant.......1,300 rpm.
    A second test was with a 3 flute carbide end mill, 45deg helix, 1,000 rpm, 7mm depth of cut and a 40mm/min feed rate in 304 stainless.
    Ian.
    Feb 2005
    handlewanker, 3 flute carbide is great at 1300rpm, Spindles can't turn below 8,000RPM normally.
    Sep 2006
    Hi....I did say the UTUBE example was on a manual mill, something like a BF20 or other..........if you are using a watercooled high speed spindle......8,000 to 24,000 rpm...... then you'll have to use some other method, like a conventional driven spindle with a VFD etc.
    Ian.
  7. #7
    Nov 2013
    I use a lot of very small endmills mostly from Kyocera Tycom and I get them at good prices
    https://www.ebay.com/str/carbideplus
    Craig
  8. #8
    Jul 2017
    I get all my cutting tools, collets, etc. at MSC Industrial (MSC Industrial Supply - Metalworking tools and MRO Supplies). I typically use 2-flute HSS miles for all the work I do. Accupro is my preferred brand.
  9. #9
    Sep 2005
    Try Amazon, MSC is so high priced I usually spend $20-30 USD sometimes more and they are decent bits. Never more than 2 flute with these High speed spindles.
    1000x750 Workbee CNC - Mach4 - PMDX USB - Windows 10 Pro
  10. #10
    Apr 2020
  11. #11
    I have been getting the bulk of my carbide cutters from Yonico on eBay
    cheers
    Sean
