Screw drives and linear rails and wood dust - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
Thread: Screw drives and linear rails and wood dust
  1. #21
    Member peteeng's Avatar
    Jul 2018
    dum dum
    Default Re: Screw drives and linear rails and wood dust
    Hi Gerry - No its the correct technical term although whipping is used a lot. Its in all the text books. whipping, whirling and critical speed all same...Peter
  2. #22
    May 2005
    I think your friend is pointing out a real issue. How bad it will be depends upon the type of dust you produce.
    In any event good maintenance prevents a huge problem from developing. Periodic greasing or oil lube is a must. The last thing you want to have happen is bearing tunnels gumming up causing a bearing to drag. Once this happens you can see some nasty wear as the balls drag instead of rolling. The carriages can actually lock up in extreme cases.
  3. #23
    May 2014
    I'd like to work through the whip calculation posted above, but have a couple questions. First, how will I know the density? And what is "E"?
  4. #24
    Jul 2018
    dum dum
    Hi Jandy - Steels density is 7830kg/m3 which is in the example twice. Its symbol is rho or the funny "P". and steels modulus is E=205GPa. Which is in the example. Ho Ho Ho Keep making Peter
  5. #25
    Apr 2007
    u s a
    Quote Originally Posted by Jandyman View Post
    this may be a little easier for you.
    Metric Critical Speed Calculator | Nook Industries
  6. #26
    May 2014
    Thanks! I had found that after I posted, and determined that running a 1610 ball screw over about 50" would be no problem with double bearing mounts at one end and single bearing at the other end. Doing a rapid at 300 ipm would require 750 rpm at the motor, which is apparently doable with the right motor and drivers, and it looks like I have the right motor. I learn so much on this forum!
  7. #27
    Apr 2007
    u s a
    one thing to take note of is the torque speed curve of your motors the stepper motors tend to drop off in torque on the high end quite a bit. 750 is not near that so you should be ok as long as you are not under sized on your motors. it's an adventure and you do learn a lot by doing it yourself. even if it's what you should not do i'm guessing your running steppers i hope i was right? if you have servo's you have a ton of wiggle room they do well over a wide range of speed.
  8. #28
    May 2014
    Yes I have steppers. I'm told here on the forum that as long as I have low inductance motors (I do), good drivers (GeckoDrive 450, so ??), and high voltage power supply (probably need to upgrade), then I should be good. Plus, I only need 300 IPM for rapids, no need to cut over 100 IPM.
    And yes, the journey is part of the fun. No sane person would head down this path LOL.
  9. #29
    Jul 2018
    dum dum
    Hi Jandy - Welcome to the asylum. Peter
  10. #30
    Apr 2007
    u s a
    think you hit the nail on the head on this
