New 2x4' router build - Page 2
Page 2 of 2 FirstFirst 12
Results 13 to 17 of 17
Thread: New 2x4' router build
  1. #13
    Jan 2016
    Default Re: New 2x4' router build
    Very helpful, thank you. What coolant do you use or recommend?
  2. #14
    Apr 2016
    Quote Originally Posted by koenbro View Post
    I use KoolRite 2290, which I bought on Amazon. It's a water soluble oil. The mix ratio is printed on the 1 gallon jug I purchased. It goes far. If you can capture the used liquid, you can strain and reuse it. Makes it even more economical. I have a small mill and mainly cut aluminum, although I also do some steel. It has worked fine for me. I especially like that it doesn't cause my mill to rust.
    Gary
    The Old Man and the C -----NC
  3. #15
    Feb 2005
    I built my mist coolant system for about $100.
    Used this mist unit from amazon.
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Was running a bit heavy on the coolant in this video, Koolmist77.
  4. #16
    Jan 2016
    So the progress today: I assembled the base (extrusion) and cut the 2x2" tube for the legs.
    Then tack welded the frame on which extrusion will sit, and checked that it was square and flat:
    New 2x4' router build-dscf7549-jpg
    Encouraged by this I welded up the pieces:
    New 2x4' router build-dscf7560-jpg
    But then it was not flat anymore, basically folded across one diagonal, by about 3-4mm. So I cut up two welds that shrunk too much:
    New 2x4' router build-dscf7557-jpg
    And lo and behold, the frame flattened out (to within garage tolerances). Pretty cool!
    Chastened by this, I only tacked the legs, with braces 3 inches above the bottom. Will attach the legs to the frame tomorrow, then add the cross braces on the other two sides.
    This is the progress thus far:
    New 2x4' router build-dscf7563-jpg
    Then it was time to close up shop for the day:
    New 2x4' router build-dscf7562-jpg
    But not before I ordered the coolant from McMaster- Carr.
    Attached Thumbnails Attached Thumbnails New 2x4' router build-dscf7557-jpg   New 2x4' router build-dscf7549-jpg   New 2x4' router build-dscf7560-jpg   New 2x4' router build-dscf7563-jpg
  5. #17
    Jan 2016
    Today I woke up early, and tacked up the legs and the cross beams and added the adjustable legs:
    New 2x4' router build-dscf7567-jpg
    So the base is now half-way done. I would welcome any suggestion on how to organize its volume for storage; can't afford to let it go to waste.
    New 2x4' router build-dscf7570-jpg
    Will most probably add a cross beam to create a 6" top shelf. Half of the width will be for a shelf for temporary storage, the other half will be a drawer, or something like that. I do like having a shelf under the work area to put stuff out of the way, like on my fixturing tables:
    New 2x4' router build-dscf7571-jpg
    Any advice? Thank you.
    Attached Thumbnails Attached Thumbnails New 2x4' router build-dscf7571-jpg   New 2x4' router build-dscf7570-jpg   New 2x4' router build-dscf7567-jpg
