It sounds like your machine came with a general-purpose controller which is suitable for a range of spindles, not just the HSD. I wouldn't run the HSD much lower than 18,000 RPM. Just don't use the codes corresponding to lower speeds. Running high-speed spindles at low speeds can damage them, since they depend on fan cooling. Also, the torque drops off rapidly, so they don't work well at those speeds either.
