Need Help! Syncing/Squaring Gantry Mach3 Settings?
Results 1 to 5 of 5
Thread: Syncing/Squaring Gantry Mach3 Settings?
    Dec 2005
    Default Syncing/Squaring Gantry Mach3 Settings?
    Finishing up my 4848. I am having probs with syncing/squaring up the gantry.
    A is slaved to Y.
    If I don't select "Home with Slave" when homing the motors spin opposite.
    When Jogging they work as expected.
    Prob with Home with slave is they only use one of the two proxy switches and don't square the gantry individually.
    Do I need to remove "reverse" A in homing and limits on my slave axis and reverse A wiring. What settings do I need to have set?
    I am getting so much conflicting info from google search.
    BTW I have edited the Ref Home script already to home Y and A together "Refcombination (10) which helped my current settings. Do I need to change this back?
    TIA
    Feb 2005
    Default Re: Syncing/Squaring Gantry Mach3 Settings?
    Sounds like you have your positive and negative homing setup wrong on your A axis. If your motors work fine while jogging that means the motors are wired correctly.
    On your homing and limits screen look for "HOME NEG" and the settings for your Y and A axis.
    Mar 2003
    Shelby Township
    Try "Home Neg" on the one that moves the wrong way?
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
    Dec 2005
    This is my current settings...
    Both Y and Slave Y(A) are wired the same to the controller.
    I originally assumed reversing it in Mach3 wouldn't present an issue down the road, I might have been wrong.
    Thanks for any help,
    Eric
    Attached Thumbnails Attached Thumbnails Syncing/Squaring Gantry Mach3 Settings?-genconfig-png   Syncing/Squaring Gantry Mach3 Settings?-homelimits-png   Syncing/Squaring Gantry Mach3 Settings?-salveaxis-png   Syncing/Squaring Gantry Mach3 Settings?-portspins-png
    Mar 2003
    Shelby Township
    Y and A should have the same "Home Negative" setting. Did you always have them different?
