Linear Rails
Results 1 to 7 of 7
Thread: Linear Rails
    Aug 2005
    Default Linear Rails
    Are linear rails and carriage blocks an interchangeable industry standard? Meaning if I purchase a cheap carriage of the same size to add on to CNCRP's rails would there be potential compatibility issues? Could I buy a third party rail to extend a machine?
    Feb 2011
    Default Re: Linear Rails
    They are not standard, though some brands may be compatible. You would have to check manufacturers specs. Profiles and mounting holes will differ between brands. Automation Overstock produces rails and blocks that work with an older Hiwin profile, but I don’t know of other examples of cross compatibility.
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Actually, they are interchangeable with current Hiwin HG series.
    I think mounting hole locations are somewhat standard, but nothing else usually is.
    UCCNC 2017 Screenset
    Feb 2011
    Ahh I did not realize the HG series was still current!
    Feb 2005
    I took a chance and order the BLH chinese rail from automationoverstock.com. I will deffinitely be posting on how it works out.
    Member peteeng's Avatar
    Jul 2018
    dum dum
    Hi Infamous - Its usual not to mix cars and rails from different makers. They are made to an industry std but the std is for overall dimensions and hole spacing and such. So for instance if you use a hiwin 20mm combo you can replace it with a PMI combo. But I've found the actual race height to be different and the shape of the area around the race to be different so WON car seals won't go on HIwin rails or others. so expect some differences. Peter
  7. #7
    Feb 2005
    So my converted machine with BLH Linear rails is up and running.
    I must say the rails do seem to deliver on quality for the price, I don't have any good pictures because my phone really can't take macro shots. But I am getting perfectly smooth edge finish in acrylic that I have never got before on the CNCRouterParts standard carriages.
    Totally happy with the BLH rail so far.
Linear Rails
Linear Rails
