Sharing my touch plate mod
Results 1 to 4 of 4
Thread: Sharing my touch plate mod
    Default Sharing my touch plate mod
    This has probably been done before but this is a simple mod that I did to the touch plate magnet. The wire kept breaking at the lug joint so this prevents this from happening by adding the wood handle so that no force it put on the wire when removing the magnet from the cutter.
    Attached Thumbnails Attached Thumbnails Sharing my touch plate mod-unnamed-jpg   Sharing my touch plate mod-unnamed-1-jpg
    Mar 2011
    Default Re: Sharing my touch plate mod
    Neat idea, though I just permanently attached the wire to a metal component and just zero it the usual way.
    Apr 2004
    Neat Idea. But a little rough on implementing. I'm going to model a 3d printed solution with a nice thumb tab to do similar, if you don't mind.
    (PS. I've already repaired my broken wire once, getting close again now).
    Feb 2005
    I just grounded my metal frame to my cnc controls, no wire needed to connect to the spindle.
