Opinions on how to move a CNCRP 5' x 10'
Results 1 to 6 of 6
Thread: Opinions on how to move a CNCRP 5' x 10'
    Jan 2016
    Default Opinions on how to move a CNCRP 5' x 10'
    I want to reorganise space inside my shed (rotate 90deg and move 4 feet) and was wondering if anyone's got
    advice on how to move the table around safely ..
    (Ideally not having to take it apart)
    I have a pallet trolley which I was going to use but I think there's going to be some
    extra reinforcement required due to the lack of rigidity of the frame ( another project soon !)
    and the point loading the middle legs will take.
    Don't really want to bend anything if there's a risk of that.
    Member ubergeekseven's Avatar
    Mar 2017
    Default Re: Opinions on how to move a CNCRP 5' x 10'
    When I asked a similar question to cncrp directly, they suggested mounting swing up trailer wheel jacks on the legs. I have not done that, but it seems doable. They did say that after moving at all, I should square up again.
    I sent them a link to some heavy duty casters that recess by dialing up and down and each was dated at 500lbs. They would attach to the same place the leveling feet do. They suggested against it and instead gave the suggestion above.
    Sent from my SM-N960U using Tapatalk
    Jan 2015
    I bought a pair of 16’ long 6x6 posts and put heavy duty furniture dollies under them. Then I got a tilt back tow truck out to pull it up on the flat bed. Nerve racking but worked well.
    David Gage
    Deep Sea Sound
    May 2010
    For your move within the shop, maybe the local high school football team... Just a thought. I had half a dozen guys help me load and unload my 4x8 into a uhaul. But I did remove the gantry for that move.
    Sent from my Pixel XL using Tapatalk
    Sep 2005
    I have two Harbor Freight lightweight 3 ton or less rated aluminum floor jacks with wheels of course. I just chuck either some 4x4 s or larger under the ends, jack and move machines
    anyplace I need In the shop.
    I guess I would have an issue having 20 teenagers in my shop, looking things over!
    1000x750 Workbee CNC - Mach4 - PMDX USB - Windows 10 Pro
    Jan 2016
    Thanks everyone .. did it with pallet jack and a hydraulic lifting table.
    Was nerve wracking to try and synchronise the lifting and dropping to not bend the table.
    Will need to replace the standard aluminium leg kit with some steel beams
