Newbie Spindle speed
Results 1 to 9 of 9
Thread: Spindle speed
    Member Brandnewnoise's Avatar
    Jun 2019
    Default Spindle speed
    Hi all!
    Got my new pro series plug’n’play machine running but can’t seems to figure out how to get the spindle to run higher than 12000. I can adjust slower in Mach 3 but nothing higher than 12000. It should be able to run 24000.
    Thanks!
    Feb 2005
    Default Re: Spindle speed
    have you reached out to AvidCNC for support, they are usually very knowledgable.
    What kind of VFD you have?
    What is the Frequency did you set?
    if you have the HY VFD, you need to set PD144 to 3000
    Check here:
    https://www.automationtechnologiesin...-110vac-input/
    Jun 2019
    Quote Originally Posted by automationtechinc View Post
    Check here:
    Thanks!
    I’m running the 2.2kw plug and play spindle/ vfd system.
    GMT 2.2 kw (3hp) air cooled
    Thanks-
    Apr 2016
    Quote Originally Posted by Brandnewnoise View Post
    Thanks!
    Thanks-
    I guess it's not so plug and play. As nlancaster suggested, reach out to CNCRP/Avid CNC. In the interim, since it's a weekend, you may want to check your Spindle Pulley setting in Mach3. It's under the Config menu. If you don't have it set right, you can get what you are seeing. (Been there, done that). Minimum should be 0. Maximum should be 24000. Ratio should be 1.
    Gary
    Feb 2005
    oh yeah, pulley setting tripped me up too in mach3. When I setup my HY VFD and Chinese Spindle.
  7. #7
    May 2018
    Minimum should be 8000 unless you want to burn your bearings up. Less than 8000 it won't produce enough air flow to cool it.
  8. #8
    Apr 2016
    Quote Originally Posted by mpoling View Post
    Good point. I forgot that we're talking air cooled. Mine is liquid cooled, so no worries for me.
  9. #9
    Jun 2019
    Thanks! I ended up needing to do a reinstall of Mach 3. That seemed to have fixed all issues related to the spindle speed but thanks for the heads up about spindle pulley settings. Will most certainly come in handy in the future.
Spindle speed
Spindle speed
