CNCRP 48x48 Pro for machining aluminum? - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
Thread: CNCRP 48x48 Pro for machining aluminum?
  1. #21
    Feb 2005
    Default Re: CNCRP 48x48 Pro for machining aluminum?
    Saw your video, congrats on your new machine!
    You should get or build a fogbuster type coolant system for cutting metal on your machine.
  2. #22
    Member cowanrg's Avatar
    Oct 2004
    Quote Originally Posted by nlancaster View Post
    Yep, that's on the to-do list. I actually have a second head for the fogbuster on my Tormach, so I might just use that and make my own tank for it. I'm not sure how to deal with the MDF, I don't want it getting damp of course.
    YouTube Channel: https://www.youtube.com/c/RobertCowanDIY
  3. #23
    Aug 2019
    Just saw your video can you give more info on the current proximity sensor setup. This looks different than what is shown in other images I have seen. Specifically the Y axis sensors.
  4. #24
    Aug 2005
    Quote Originally Posted by cowanrg View Post
    I was originally going to get a larger CNC vertical mill, so this is actually quite a bit cheaper, so I can throw a bit more money at it to get the most out of it.
    Robert,
    Do you have any impression on your new machines on cutting aluminum in comparison to your tormach as a reference. I am curious on the speeds / depth of cut / surface finish capability.
  5. #25
    Apr 2004
    Has anyone tried just using air blast for cooling rather than liquid coolant? Would love to do more aluminum, but the mess.....
  6. #26
    Aug 2017
    I have the Benchtop Pro 2436 and have had no problem machining 6061.
    - - - Updated - - -
    The most I use for 6061 on my Benchtop Pro is spray lube. I usually cut it dry with ZRN-coated tooling.
