Weird surface on profile cuts
Results 1 to 3 of 3
Thread: Weird surface on profile cuts
    Jun 2017
    Default Weird surface on profile cuts
    Weird surface on profile cuts-20190409_175812-jpg
    I just noticed this occurring on a job I just finished. I routed a total of 6 signs all had this type of finish on the edges.
    Material is kiln dried Maple.
    Bit is a new Onsrud 40-112 1/4" downcut
    Any help is greatly appreciated
    Gary
    Jan 2015
    Default Re: Weird surface on profile cuts
    This is what the Separate Last Pass (offset) features in Vcarve and Aspire is meant to address. Usually on one of the sides of the Baltic Birch plywood I was cutting, I’d get a rougher cut and I’m sure it was due to the grain of the layers. So I added a separate .02” last pass with a depth of about .05” (modifying the pass depth so the first 2 passes went near full depth on the 3/4” plywood). Since adding this, all my cuts have been accurate and clean. You could also play around with which way you are cutting, climb vs conventional, as that could also impact cut quality.
    Edit - I was looking for the Vectric manual but I at least found this, which shows a picture of the feature.
    Vectric Forum • View topic - separate last pass
    David Gage
    Deep Sea Sound
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    You're getting deflection somewhere.
    I make a single full depth finish pass of about .02", at about 150ipm.
    I'd also recommend using a 3/8" bit, whenever possible.
    UCCNC 2017 Screenset
