You could have more than one thing causing your problem, what spindle and VFD Drive do you have and has the VFD Drive been Programed correct, when the spindle runs for 30seconds does it give a faultI need help setting up the plug and play spindle with my older Pro 4896 table(crp300 electronics).
I have set up all the hardware according to the instructions that came with the spindle setup. I have checked and triple checked the settings that I changed in Mach 3 based on the instructions from cnc router parts. When I press the test button on the PMDX 107 the spindle runs for 30 seconds. The issue that I'm having is that now Mach 3 doesn't seem to do anything at all. Not only does the spindle not move thru mach but nothing else does either. It appears to recognize its connection to the smooth stepper, and no errors seem to be present. The smooth stepper lights appear normal. For some reason the "outputs enabled" LED on the pmdx 126 is not lit. When I try to jog any axis the DRO moves in mach 3 as it should but it has no effect on the table. Same deal with the spindle controls on the mach screen. Does anyone have any ideas for me to try? I need the table for a big project that starts on Wednesday and I'm starting to feel a little bit nervous about getting it back on line by then. This was a table that I bought used last year and I have been using it with no problems with a porter cable router...If I can't get control of the spindle is it a simple matter of changing all the mach and pmdx126 settings back to how they were or only some of them? Can I leave the speed control card connected(pmdx 107)? EDIT- If I disable charge pump I can get everything to work...Is it ok to run it like that?
Thanks in advance, I'm going a lil' nuts here.
