Newbie CNCRP Benchtop Pro or Standard 2424 - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 35 of 35
Thread: CNCRP Benchtop Pro or Standard 2424
  1. #21
    Default Re: CNCRP Benchtop Pro or Standard 2424
    Quote Originally Posted by ger21 View Post
    Chinese air cooled spindles are very quiet, and don't blow a lot of air.
    I've seen the argument about the spindle blowing chips around a LOT over the years. My opinion is that you should have a dust collector many times more powerful than the spindle cooling fan, which makes this point invalid. Without a decent dust collector, you'll have a room full of chips, and dust everywhere. A lot more than you'd think.
    And with air cooled, you don't have to deal with any water cooling hassles.
    I'd never pay $1700 for their spindle when I can get this for $300. But then I design and build my own machines.
    https://www.ebay.com/itm/251263506939
    (I own this VFD and two of these spindles)
    The CNCRP spindle is probably louder than the round chinese spindles, as the square ones have different fans and better cooling. But a haven't heard anyone say they weren't happy with their cheap, round, chinese spindles.
    I would not recommend a normal router. The bearings just won't last long.
    Hmmmm, so much good advice from you, really might convince me to go air instead of water. I have only found a couple youtube videos comparing these, and the water ones did sound a lot quieter (albeit I dont know if they were comparing apples to apples of spindles).
    Maybe I ditch the water cooling idea, and simply build an enclosure for sound suppression for the spindle and the milling.
  2. #22
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    While I haven't actually cut anything with my air cooled spindles, I've run them quite a bit on my bench. At 8000 rpm, the cooling fan in the VFD is louder. They aren't nearly silent like a water cooled, but you'll find the cutting noise to be much louder.
    UCCNC 2017 Screenset
  3. #23
    Thats the other thing I never see in the videos. Comparisons when they are actually cutting. Real life tests vs comparisons for the camera.
    PS, you're getting close to 33,333 posts, cool photo to take, imo. Thats a lot of posts.
  4. #24
    Mar 2003
    Shelby Township
    If you are using a 1/4" tool or larger, cutting noise will usually be louder than the spindle. The exception would be with very light passes, at very high rpm, where the spindle is at it's loudest.
    For example, my machine is in my attached garage, and my family room on the other side of the wall. When in the house watching TV with the machine running, I only hear it when it's actually cutting.
  5. #25
    Hmm, we have pretty good sound proofing between units, but will definitely ask the neighbors if they hear anything to ensure I am being a good neighbor.
    Ok, down to the last decisions.
    Do I go with the Benchtop Pro 2424 for the Pro4824. They both weigh in around 250lbs, and based on my mill research, the more weight in a given package size the better it is a milling metals. Being close to 1/2 the size, I would have to assume the Benchtop has to be a decent amount more rigid. Does the ball screw vs rack and pink drive impact that? The ballscrew is the preferred method of heavy milling, so I assume the best. Does rack and pinion create a loss of rigidity under force?
    All that being considered, does it matter? Will both do a similar job? Is the sacrifice of stiffness worth the extra 2 feet or vice versa?
    Doing a little research, its clear the CNC's offered in the range I am looking at, note that they are good for aluminium and softer. They don't even come near to recommending for steel or harder. When looking up the hardness of aluminium to steel, its usually only a .5 to 1x increase when looking at various types. Its crazy that not even a double of harness can go from fully capable to not even recommending it. So much for me to learn.
  6. #26
    Mar 2003
    Shelby Township
    The simple answer is that it's not that simple.
    I just did some searching, and found a chart that stated the Mohs hardness of steel can be 5x more than aluminum.
    But I think that steels other properties are more important than hardness. With aluminum, the harder alloys can actually be easier to cut, because they are not as gummy.
    I'd call or email CNCRP and ask them which machine they feel is more rigid. Tell them what you want to do with it, and ask their recommendation?
    I would expect the 2448 to use larger, more rigid components. But yes, the larger size allows for more flex.
    I don't think that you'd come anywhere near exceeding the force holding the pinon into the rack, so it houldn't be noticeably less rigid.
  7. #27
    Member peteeng's Avatar
    Jul 2018
    dum dum
    Hi Mithiral - It's not the hardness that makes cutting steel "harder" its its stiffness and strength. Steel is three times stiffer then aluminium and most steels are much stronger then aluminium. So the cutter has to overcome the metal stiffness to start a cut (so you need 3x more effort to deflect the chip) then the tool has to shear the metal, steel being stronger needs more power and these are multiplying factors not additive. Then if the machine is not stiff enough to keep the tool steady it will never start a chip it will just deflect around the cut then slide along the surface resulting in blunt tools etc. Really need a mill for cutting steel. Look up chip load charts and power charts for cutting and you will get an understanding. Mills look like mills and routers look like routers for a reason. Peter
    To put this in perspective and only consider the materials stiffness as a basis. The tool has to deflect the material to start a chip then the tool has to shear the material to remove the chip. The stiffness of plastic is 3000 to 4000MPa. Sorry I'm metric (1MPa = 0.15 ksi you can do the math) The stiffness of hardwood is about 20000Mpa the stiffness of aluminium is 70000Mpa and steel is 200000MPa. For interest titanium is 110000Mpa. So a machine designed to cut plastic and timber at best needs to be 200/20 = 10x stiffer to cut steel. This is a huge difference and this is a simple comparision approach. When you take the material strength and other factors into scope its a very serious upscale to get to a mill machine. You can cut aluminium in a router but its a compromise on feeds and depth of cuts and tool wear to get it happening. Otherwise mills would look like routers as they are cheaper to make. Cheers 2 Peter
  8. #28
    Apr 2016
    Quote Originally Posted by wmgeorge View Post
    My air cooled spindle does not blow dust around. You will need a dust collection system anyway. Water cooled is a pain. I had one and my laser is water cooled also. Unless you run a sealed system with a refrigerated chiller like my laser, you will need to deal with algae.
    I use a water cooled 2.2kw spindle and am happy with it. I don't find it to be a pain at all.
    You can avoid the algae problem by using RV antifreeze (propylene glycol), What I use has corrosion inhibitors and is pet safe (although my two dogs don't ever get anywhere near it), I have a couple of gallons in my holding tank (aka poly storage bin) where it has been for the last couple of years. Nothing growing in it. You can pick it up at Wally World for about $2.50/gal. If you get a concentrate (I don't), be sure to use distilled water to dilute it. Don't want a bunch of minerals trying to clog the spindle coolant passages.
    I use a 12V submersible pump (https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1) and and a small, 2 fan, computer radiator. Router stays nice and cool - never gets even slightly warm. It's surprising how little liquid flows through it. Little more than a trickle. Does the job though.
    The air vs water cooling is a long running debate. It's just a matter of what you land on. When I bought mine, most folks seemed to lean toward water cooled, so I went that way. If I had to replace my spindle, I'd probably stay with water cooled. But that's just me. Your mileage may differ.
    I can attest that water cooled are pretty quiet when not cutting, but the noise level goes up significantly when it's cutting. I have never owned an air cooled spindle, so I can't offer any comparisons on noise.
    Gary
  9. #29
    Yea, I didnt get far into the research, obviously a lot to learn.
    I did call and ask about the pro vs standard on stiffness and they werent very helpful, ha. It was pretty vague, yea, pro is stiffer. Would be great if there was more than just resolution, accuracy, and repeatalbity. Like 1,000 of a inch deflection when 25lbs of force are applied to the spindle bottom. Probably thought of, argued over, and never adopted.
    Quote Originally Posted by peteeng View Post
    Thanks Peter, yea, sounds like a lot more going on than the couple of charts I looked at
    Quote Originally Posted by GME View Post
    Gary
    I will need to go and do some more reading to make sure I make the best choice. Thanks for your thoughts.
  10. #30
    Sep 2005
    RV Anti freeze is not 100% algae proof, I have had it in mine. I think its DowTherm is the chemical we used in solar systems? I am hoping my system does not have algae again it was a pain to get cleaned up. YMMV. I may go to standard automotive anti freeze made for aluminum engines.
    1000x750 Workbee CNC - Mach4 - PMDX USB - Windows 10 Pro
  11. #31
    Talk to Ahren, gave me some good info. Yes, the benchtop pro is their stiffest most accurate machine. 2'x2' with ball screws leads to a very sturdy machine. That said, they have folks running their big tables with detailed aluminium projects with no problem. For my space limitations, the benchtop makes the most sense as thats exactly what they were designed for.
    On a side note, just touched base with one of my old high school buddies I hadnt chatted with since Dec, on a random note we got talking about CNCs, he's buying their 5'x10' table soon.
    So yea, might just go in with him and get best of both worlds. Use of an awesome CNC without losing space in my garage
    Thanks all for the amazing help!!!
  12. #32
    Aug 2017
    Awesome machine options, in the same boat here.
  13. #33
    Aug 2017
    Quote Originally Posted by ddurbs21 View Post
    Is there such thing as a VFD with 110V input that will run one of the Chinese 2.2kw water-cooled spindles?
    For what it's worth, I've been using this set for almost a year now with zero issues. I see others warned against it but I've had very good luck so far. Your mileage may vary.
  14. #34
    Member ddurbs21's Avatar
    Oct 2018
    Quote Originally Posted by retrosmith View Post
    Awesome, something to look into. I don't mind running a dedicated 220 but I'm also not sure my kit won't be mobile depending on the use.
  15. #35
    Mar 2018
    Quote Originally Posted by mithiral67 View Post
    did you pulled the trigger on the benchtop pro for milling some aluminum, i am questioning myself if i go diy or get a benchtop pro. i sold my previous cnc before starting the next one, so i am here with no tool in need a a small router.
    your feed back would be appreciated.
