Need Help! Machine can't cut straight angled lines.
Results 1 to 4 of 4
Thread: Machine can't cut straight angled lines.
    Mar 2016
    Default Machine can't cut straight angled lines.
    My machine is making jagged lines when cutting 45 degree angle paths.
    Anyone know why this might be? I've searched for loose screws and wobbly connects - but everything seems tight.
    Is there a quick fix for this glitch?
    Machine: CNCRouterParts Pro 48x96
    Cheers,
    S
    Attached Thumbnails Attached Thumbnails Machine can't cut straight angled lines.-img_20190304_133212-jpg
    Sep 2005
    Default Re: Machine can't cut straight angled lines.
    Will it cut a straight line, will it cut a box accurately or do a circle the size its drawn at? If not it could be your Steps are off. Check and see or test.
    Retired Master Electrician, HVAC/R Commercial. FLA Saturn 2 4x4 CNC Router
    Mar 2016
    Found the problem!
    After tearing it apart - tte X axis belt was.... ruptured.
    Not sure how that happened.
    New parts ordered.
    Cheers!
    Mar 2016
    Yup. New belt. Work perfectly now.
