Need Help! CNC Router Parts 4x6 machine
Results 1 to 4 of 4
Thread: CNC Router Parts 4x6 machine
    Registered Tonyscnc's Avatar
    Oct 2018
    Default CNC Router Parts 4x6 machine
    I have a CNC RP 4x6 and do lots of 3D woodworking... just in the past 3 weeks, I noticed in doing a finish cut, that "Z" moves up .03 +- and my finish cut is no more. Tried doing a run in "air". same results. and there is no slippage in the couplers (have index marks to make sure) Collet is good as I measured bit before & after but running in "air" without spindle running proves that it is not in the collet. Any suggestions?????
    Tony K.
    Mar 2003
    Shelby Township
    Default Re: CNC Router Parts 4x6 machine
    Make sure that there's no binding in the Z axis.
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
    Member he1957's Avatar
    Jun 2018
    Check the seating of the bearings for the Z shaft where they sit in their mounting blocks and the ball screw nut mounting is not loose.
    Sep 2005
    I may not know all the details, but I think if a ball screw nut or whatever has had a lot of use they may need adjusting as it gains some slop. That is assuming yours or mine are adjustable.
    https://www.thomsonlinear.com/en/tra...screw-assembly
    Retired Master Electrician, HVAC/R Commercial. FLA Saturn 2 4x4 CNC Router
