How critical, if at all, is using shielded cable inside the controller box? My set up will be running off the DB25 inputs/outputs on the Acorn - so low voltage and not optically isolated. All of my VAC stuff and VDC power supplies are at the top of the enclosure, the Acorn and DYN2 drivers are at the bottom. Do I need to use shielded twisted pairs for step and direction, or VFD spindle speed output, or DC power to the drivers, or will plain old 12-14-16-18-20-22 AWG wires work?
