Anyone mount a video camera on the z-axis?
Results 1 to 6 of 6
Thread: Anyone mount a video camera on the z-axis?
    Registered pugsly's Avatar
    Jun 2015
    Default Anyone mount a video camera on the z-axis?
    Hi, I was wondering if anyone had mounted a camera on the z-axis for remote monitoring (broken tooling, etc)? I have a 4x8, so I don't think a USB camera because of the length of cable required. Thanks!
    Registered ubergeekseven's Avatar
    Mar 2017
    Default Re: Anyone mount a video camera on the z-axis?
    Yep. I have a raspi zero with a wide angle lens attached. The board is $5 from microcenter and the camera is $20 from Amazon. I printed a case for it that resembles a web cam. Then I power it from a power strip I have on the gantry. I used a bolt to attach it with an aluminum plate to the z axis. It does timelapse and video and live stream through a web page local to my network.
    https://myhub.autodesk360.com/ue29bb...0320a1d03fd825
    That's the case.
    michaelDot.com is my site. Not much on it, but I went over part of that video camera on it. Under the 4th axis stuff. Also made linear bearing rail covers that are working insanely well and I accidently made them capable of self cleaning using the vacuum at the end of a job.
    Sent from my SM-N950U using Tapatalk
    Registered Jim Dawson's Avatar
    Dec 2013
    Yes, I have done that. Using a camera like this https://www.ebay.com/itm/5-7-8-mm-An...tCbw:rk:1:pf:0 This one has a 10M (30ft) cable
    Live streamed using YouTube that way you can monitor from anywhere on any device.
    Here is how I set it up on my mill. It has a built in light source and actually works pretty well. Its small size allows mounting almost anywhere. I just used the mill computer to live stream, but you may have to use a seperate device depending on your software.
    Anyone mount a video camera on the z-axis?-img_1814small-jpg
    Here is a picture of a job running on the mill, this was taken at my sons house on his internet connected TV. He lives about 10 miles from the shop. This was about a 9 hour run so we were running dark.
    Anyone mount a video camera on the z-axis?-big-screen-jpg
    Attached Thumbnails Attached Thumbnails Anyone mount a video camera on the z-axis?-big-screen-jpg   Anyone mount a video camera on the z-axis?-img_1814small-jpg
    Jim Dawson
    Sandy, Oregon, USA
    Mar 2003
    Or just throw a GoPro on it.
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
    Mar 2017
    Quote Originally Posted by ger21 View Post
    Monitoring the GoPro remotely is an issue. That's why I switched mine out. Mine is about the same size and does everything onboard. Nothing else required. GoPro has a way to connect wireless, but it's terrible resolution and requires using WiFi on a device. You can stream it with a browser, but the feed is very low quality.
    Jun 2015
    gotta say I like the simplicity of that borescope camera, think I'll give that a try before anything else. Thanks for the quick responses everybody!
