4th axis touch probing - Page 11
Page 11 of 11 FirstFirst ... 891011
Results 121 to 128 of 128
Thread: 4th axis touch probing
  1. #121
    Member dharmic's Avatar
    May 2015
    Default Re: 4th axis touch probing
    Kudos to someone who can park their ego long enough to recognise and admit to themselves (noone else really matters) that they've been caught up by their own brain. Chill, or better: laugh, man. We are funny critters and we're wired weird.
    Chuckles aside - you (and now I, thanks again!) are up and running with our freshly dialled in 4th axes, so I'm gonna count this one a win
  2. #122
    Mar 2008
    I have been able to successfully integrate a laser fork sensor as a "no touch" probe. Although this example is on a wood lathe, the same exact principle would apply to a metal lathe. I used the "Digitizing Bundle" option available with the Centroid Acorn and take the digital point output via a Vectric gadget and direct import into VCarve Pro software.
    Here is a peek:
    Similar videos on my YouTube page: https://www.youtube.com/user/Islaww1/videos
    Gary Campbell CNC Technology & Training
    Control & ATC Retrofits
    GCnC411 (at) gmail.com [url]www.youtube.com/user/Islaww1/videos[/url]
  3. #123
    Member ubergeekseven's Avatar
    Mar 2017
    Quote Originally Posted by islaww View Post
    Here is a peek:
    That's pretty nifty. Fast too.
    Sent from my SM-N950U using Tapatalk
  4. #124
    Mar 2017
    So, I started a new post for this issue and have an active post on the Fusion 360 forum as well as the warp9 forum for my motor controller and some issues I have with my rotary axis speed when doing wrapped jobs.
    I use both Aspire and Fusion 360. WIth Fusion 360 I have been playing around with mixing wrapped and indexed toolpaths so that I can cut planar and wrapped output. All works well until a retract and movement to the next cutting position occurs. My A-Axis is a 100:1 reduction and the movements during retract-positioning for the next cut are insanely slow. The cutting is as I expect though. If the x-axis needs to move 15 inches from the current position and 340 degrees on the a-axis at a feedrate of 100, the a-axis moves at 100 degrees per minute and then takes 3 minutes 40 seconds to get to the next position. Then the cut take a couple seconds and repeat.
    Do you experience the same limitation on the rotary axis that I am? What CAM software are you using if you are not getting this sort of issue?
  5. #125
    May 2015
    Fusion/Mach3
    No such issue. Check your max speeds, your steps per unit (degree), your mach3 radius compensation and if all of that is sane maybe have a look at a simple toolpath as generated and see what the feedrates are on the G00 / G01 A moves.
  6. #126
    Mar 2017
    I had a feeling you would not have issues. My radius is set as 0.0001 as suggested by many people. Do you enter the actual radius each time? The movements are fine with G00 /G01 moves. I have the a-axis tuned to just below missing steps. It is as fast as possible. Everything works great until repositioning. Adaptive 2d toolpaths are the issue so far. Thanks for your info though.
  7. #127
    May 2015
    Time to check your POST configuration in 360 then. Crank out a simple wrapped slot and see what the G-code looks like, then work from there.
  8. #128
    Mar 2017
    yeah, I am working with a post processor guy from fusion right now to try and figure it out. It has something to do with the G94 moves.The Warp9 ESS controller people suggested using Mach4. Tried the demo simulation with the same results. It is definitely a post issue. I will keep at it.
