David are you saying its impossible for the LDF pores to plug with the really fine dust from the surfacing process?
Its possible also low or no voltage to the vacuum motors would cause them to not power up 100%. You would need a clamp on amp meter to verify each motor is pulling its load. To bad he is not closer, I have at least two of them I can find right now
