New Machine Build PRO4824 - Teenager Build - Page 2
Page 2 of 2 FirstFirst 12
Results 13 to 15 of 15
Thread: PRO4824 - Teenager Build
  1. #13
    Feb 2017
    Quote Originally Posted by blitzer View Post
    Thanks guys!
    Ran into my first issue. The brackets for the lower cable track fasten to the bottom of the extrusion. I did not buy the leg kit, and that is not going to work as the table is sitting on a stand and the bottom of the extrusion is not accessible. Too bad since the brackets to hold the cable track are so pretty. I will have to fashion something to attach to the table to hold the cable trays.
    Pics!
    Attached Thumbnails Attached Thumbnails PRO4824 - Teenager Build-pockets-cable-tray-brackets-1328x747-996x560-jpg   PRO4824 - Teenager Build-cable-tray-brackets-1328x747-996x560-jpg   PRO4824 - Teenager Build-cable-tracks-finished-1328x747-996x560-jpg
  2. #14
    Registered blitzer's Avatar
    Jun 2018
    Default Re: PRO4824 - Teenager Build
    Quote Originally Posted by 2012JK View Post
    Pics!
    Thanks for the ideas, unfortunately, my stand is metal with wood sides. What I end up doing is using some heavy angle irons to hold the tray. I may paint them in the future.
  3. #15
    Jun 2018
    It was been cold here in Chicago. -26 with wind chill down to -58. My 4000 watt heater was hopelessly under-gunned. So, taking a little break from wiring up the electronics.
    Also, I just did not want to use mach3 with the bull**** parallel interface. I bought the Centroid Acorn and used a modern computer. Bought a touchscreen as well to use with the Acorn. Any thoughts or experiences with this?
    Acorn CNC controller, Step and Direction 4 axis CNC Control board with ethernet communication.DIY CNC kit
