Newbie PRO4896 Cutting Melamine
Page 1 of 3 123 LastLast
Results 1 to 12 of 29
Thread: PRO4896 Cutting Melamine
    Dec 2016
    Default PRO4896 Cutting Melamine
    Anyone cutting 3/4 melamine with the pro4896 with the 2.2 kw spindle? If so could you share your settings and bit type. Getting some i fo before mine arrives.
    Registered pugsly's Avatar
    Jun 2015
    Default Re: PRO4896 Cutting Melamine
    Interested to hear what folks have to say, I know how brittle that stuff is!
    Sep 2005
    Interesting I have a much touted program G-Wizard and it does not even list Melamine as a material? The search comes up MDF and I know that's not going to work. They want $79 a year or $139 for 3 years use and it appears to have all the bells and whistles. I am using the Trial version now, maybe its a cripple ware edition.
    Retired Master Electrician, HVAC/R Commercial union shop and Lots of hobbies. FLA Saturn 2 4x4 CNC Router
    Mar 2003
    "Melamine" is most often Particle Board with Melamine faces, but it's also available as MDF with Melamine faces.
    So, it cuts the same as particle board, with the exception of the faces, which chip very easily. To prevent chipping, melamine is typically cut with compression bits, or downcut spirals if you only need one clean face.
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
    Dec 2016
    Was hoping someone using this machine could share there feeds and speeds and bit type when cutting melamine, my new pro4896 will be arriving in 4-6 weeks and was trying to get a jump on a good start point. My current cnc was the Zenbot which from previous post was not a very rigid machine but it has allowed me to do enough work to purchase the new cnc outright. I had gotten a few responses and they are using 3/8 bits, that seems like allot of waste of removing material vs using a 1/4 bit? Is it because the bigger shaft you can run faster speeds?
    Sep 2005
    Do a Search for G-Wizard. they have a "Free' download to try. You will need to input your machine name or generic and the min-max speed of your spindle and the Hp rating to get feeds and speeds you can use. Gerry says MDF is the same as Melamine and frankly I do not know but I have cur MDF and its a dusty mess. Maybe I was using the wrong settings?
    Bob from G Wizard will fill your Inbox so be aware of that. I think I am going to spring for the 3 year plan however.
  7. #7
    Jun 2017
    Whisker- I think your problem is no one is cutting melamine. There are a lot of people on here using CNCRP Pro routers of different sizes, me included. I'm new to CNC so I have no experience with routing melamine, but I know I would do some testing to see what works best for my job with my bits. I think it's going to depend on what the cuts are and if you are going completely through the material or just pocket cutting part way through.
    Like I said I'm new & I may be way off but I'd start with a 3/8" or 1/2" bit cutting 150ipm with a spindle speed of around 12000 - 15000 rpm. But like I said I'm new & may be way off.
    Good luck I'm very happy with my Pro4896 with nema 34 & CNCRP's electronics & spindle
  8. #8
    Mar 2012
    GWizard is a very powerful tool and you can modify for your machine. They are having a 20% off sale on all their software now.
    https://www.cnccookbook.com/cnc-soft...gn=offerbutton
    Here is a screenshot for melamine with a standard .25 2flute EM. There are lots of variable to make changes to the end values, so don't take this for gospel. There is a slider bar that will adjust your F&S for aggressive or finish. You also need to set depth of cut (per pass) and whether you are cutting a slot or using a stepover. A little intimidating at first, but you will get the hang of it and Bob is very good at getting back to you if you have a question.
    Attached Thumbnails Attached Thumbnails PRO4896 Cutting Melamine-melamine-jpg
  9. #9
    Jun 2017
    I've been been thinking about getting GWizard for a while. Seen like a lot of information. Who set a .25" bit cutting .1875 deep per pass? Was it you or did GWizard because of the material? This looks interesting especially for a newbie
    I have an app called FS Wizard and it seems more geared for metal machining there is a radio button for plastic, wood & hard not metal. I close hard not metal and this is what it came up with
    PRO4896 Cutting Melamine-screenshot_20181229-050345_fswizard-jpg
    Gary
  10. #10
    Mar 2012
    I set the bit diameter and depth of cut. You should download the trial version. I have tried FS Wizard too, along with many other F&S programs.
  11. #11
    Sep 2005
    FS Wizard and even the Pro version does not seem to do wood and they do not publish the material list it does do? I have a calculator on my iPhone from Vortex and it seem pretty good. You start by picking the Tool and it lists Melamine.
  12. #12
    Mar 2003
    Quote Originally Posted by beltramidave View Post
    I would consider those numbers to be way off. I'd be using 12,000-14,000 rpm at 150 ipm.
    21,000 rpm would be better suited for 450-500ipm .
