Newbie PRO4896 Cutting Melamine - Page 3
Page 3 of 3 FirstFirst 123
Results 25 to 29 of 29
Thread: PRO4896 Cutting Melamine
  1. #25
    Dec 2016
    Default Re: PRO4896 Cutting Melamine
    I have been using the 1/4 Yonico compression bits but only get two sheets before i start to see chipping out of the melamine, i still use the bits once they start chipping the melamine and i generally get 8-10 sheets of regular 3/4 particle board cut before i start seeing allot of fuzzies on the edges and degraded smooth edge. I think melamine in itself is a tough material to cut if you dont have things dialed in and get the most out of a bit.
    On a side note when cutting straight 3/4in dados what is the best method? i currently have it pocket cut the dado but i find i have to monitor the width because it gets to tight after several dados and i then have to have it overcut .01-.015 to get it so its a good snug fit, is this possible due to machine
    ridgity of my current machine or the wear of the bit itself? Picture for example what i cut.
    PRO4896 Cutting Melamine-fv24jx5ijfzzigy-large-jpg
    Attached Thumbnails Attached Thumbnails PRO4896 Cutting Melamine-fv24jx5ijfzzigy-large-jpg
  2. #26
    Mar 2003
    I'd use a 3/8" downcut, one pass down the middle, followed by one on each side. If you are climb cutting, a dull bit can cause more deflection, making a tighter fit. With a conventional cut, you shouldn't see that much difference?
    What RPM and feedrate, and how many passes? I'd make the first passes about .03" oversize, and the final pass to size. This should get you more life, and help with chipping. But if it's chipping after two sheets, you're probably cutting too slow.
    Make sure you don't climb cut, as that will chip a LOT more.
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
  3. #27
    Nov 2015
    Wisker, I also would check your sheet stock for thickness consistency. I have measured more than 0.020 variations in a single bunk.
  4. #28
    Jun 2017
    Have you tried a new bit once you see the cut size changing?
    Gary
  5. #29
    Apr 2016
    Get a quality up and down cut bit for best result with melamine at work i can cut up to 100 sheets before replacing a bit but this is on industrial machine
