Quote Originally Posted by dzsflw View Post
I have the same machine and have had trouble with this. I asked CNCRP for clarification and they said "On the bearing you have the top and the bottom that are red. One side has a screw in it. The hole to grease is on the opposite side."
Yikes!! As I understood the directions I received from CNCRP I was to remove the screw on the bearing block, instill grease through that hole, and then replace the screw. The screw is on the outside and much more accessible so the directions, as I understood them, made sense. I'll write to CNCRP for clarification.
I agree, CNCRP really should make a video!
