Non-CNCRP VFD on Plug & Play - Page 3
Page 3 of 3 FirstFirst 123
Results 25 to 27 of 27
Thread: Non-CNCRP VFD on Plug & Play
  1. #25
    Registered GigaWatt's Avatar
    Apr 2015
    Default Re: Non-CNCRP VFD on Plug & Play
    Good to hear you up and running again! I agree, CNCRP has excellent customer service.
  2. #26
    Jan 2005
    Quote Originally Posted by wmgeorge View Post
    Got the new board today, and ta dah it works. Full 400 hz at 10.6 vdc out. I have some settings to change as minimum speed and scaling so it follows the software setting. I can not say enough good things about Customer Service at CNCRP. They are outstanding.... I Wish All companies selling CNC equipment were as good!!
    That's a strange output voltage, should never be over 10v something is still wrong with the board if it does not have a pot to lower it
    Good service is apart of any business
    Mactec54
  3. #27
    Sep 2005
    Finally got back to the project. Final answer, set minimum Frequency to 150 Hz which turns out to be about 10 K Rpm and the pulley setting on #4 is now set 0 - 25,000 Rpm per ESS instructions. Board outputs 10.1 vdc at 400 Hz. So no matter what the lowest setting is, when you click on Spindle it starts and runs to about 9000 - 10,000 Rpm (150 Hz) plus it follows the setting in the software. The PWM signal Mach3 outputs gets changed as it should to a linear 0-10 vdc.
    All is fine and thanks Ahern and staff at CNCRP.
    Retired Master Electrician, HVAC/R Commercial union shop and Lots of hobbies. FLA Saturn 2 4x4 CNC Router
