How big are the parts that you cut, and how do you hold them down?
In a commercial setting, we use vacuum tables and cut in a single pass with a compression bit.
You should be able to cut in one pass, but a more powerful spindle would be beneficial to maximize tool life.
Bits last the longest when cutting with the highest feedrate, and lowest rpm (high chip load).
