Originally Posted by
sm38240
Thanks for the thoughts. The grid pattern is 104 holes on 96mm centers. The hole diameters are 20.1 mm. I use two of these holes as the reference holes, bored into my spoil board. I am using my Festool tracsaw track as a straight edge. All the holes on the first run are dead on parallel and straight. Only when I move the board to finish the last set of holes is the error introduced. You are right, 15 thou is not much, but enough to potential introduce additional error into boards you are cutting when using the MFT. I made three of these boards, trying various options to secure in addition to the reference pins, but the error was always there and on the same side. That should tell me something, but not sure what.
