Need Help! Spindle Voltage Output - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 21 to 40 of 56
Thread: Spindle Voltage Output
  1. #21
    ericks
    Guest
    Default Re: Spindle Voltage Output
    So, have you managed to fix the 0-10V issue?
  2. #22
    May 2013
    Quote Originally Posted by ericks View Post
    Not yet. I am asking CNC Router Parts if I have the wrong output or if the board might be bad. Still waiting to hear back from them. I will let you know as soon as I hear from them.
  3. #23
    ericks
    Guest
    Quote Originally Posted by millerm499 View Post
    Thats good...
  4. #24
    ericks
    Guest
    I see CNCRP suggest a base frequency of 100
  5. #25
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    The Huanyang manual shows the jumper.
    UCCNC 2017 Screenset
  6. #26
    May 2013
    Quote Originally Posted by ger21 View Post
    So I checked the jumper and it was on 2 and 3. I moved it to 1 and 2, but it still is not controlling the speed. I think I should check the PD setting. Do you have a list of what they should be?
  7. #27
    Member mactec54's Avatar
    Jan 2005
    Max 24000, min 0, ratio 1
    Sent from my SM-N950U using Tapatalk
    You can't have a minimum of 0 the minimum for your spindle is 6,000 RPM
    Mactec54
  8. #28
    Jan 2005
    What are your spindle spec's and the VFD you are using
    Mactec54
  9. #29
    ericks
    Guest
    You are missing the whole point here!
  10. #30
    May 2013
    I am using a 2.2kw spi doe with the vfd in the pic
  11. #31
    Jan 2005
    Not at all the pulley setting is just as important as anyother Mach3 setting
    Mactec54
  12. #32
    Jan 2005
    Spindle spec's are 220v that is clear by the VFD spec's
    Is it water cooled or air cooled
    300Hz or 400Hz these are important to know for what your VFD Drive Parameters will be set to
    Mactec54
  13. #33
    May 2013
    Sorry about that.
    The spindle is 400hz on 220 volts 8.5 amps
    Water cooled.
  14. #34
    Jan 2005
    Sorry about that.
    Water cooled.
    Here are what your VFD Parameters should be set to
    Huanyang Mactec54
    2.2Kw 220v Water Cooled
    PD000=0 for Parameter unlock ( 1 ) for Parameter Lock
    PD001=0 (1 For Remote Control)
    PD002=0 ( 1 For 0-10v Terminal Control or Remote Trim Pot Control )
    ( J1 Also Needs to be set for Remote Terminal Control 1-2 jumper connection )
    PD003=400
    PD004=400
    PD005=400
    PD006=15
    PD007=20
    PD008=220 (Motor Rated Voltage )
    PD009=15
    PD010=8
    PD011=100 ( 100 Minimum Setting with Quality VFD, 120 is Safe)
    PD13= 08 is for Factory reset, Only use this to set VFD to Factory Default Settings
    PD014 Acceleration=10 ( Adjust to suit)
    PD015 Deceleration=10 (Adjust to suit) ( PD15 is ignored IF PD26=1 Then the Spindle will Coast to a Stop)
    PD023=0 ( Forward Run Only )
    PD041=8 ( Carrier Frequency up to 10 Max for these Spindle motors)
    PD120=120 ( Stall Prevention )
    PD141=220 ( Motor Rated Voltage )
    PD142=9 ( Motor Max Amps 2.2Kw Spindle 9 amp )
    PD143=2 ( Motor Number of Poles)
    PD144=3000 (Max Motor RPM) =3,000= (24,000)
    PD70=0 ( This may need to be set to 1 if Control Voltage is 0-5v )
    PD72=400
    PD73=100 ( 100 Minimum RPM Setting 120 is Safe )
    PD174=11 ( To Be Set to the VFD Drives Max Rated output Amps )
    Mactec54
  15. #35
    ericks
    Guest
    I was not referring to the setting!! Anyway i won't say anything further on this
  16. #36
    May 2013
    Huanyang Mactec54
    PD003=400
    PD004=400
    PD005=400
    PD006=15
    PD007=20
    PD009=15
    PD010=8
    PD72=400
    I tried all these parameters and it is still not being able to control the spindle with Mach3
  17. #37
    Mar 2003
    Shelby Township
    What do you have for PD001 and PD002?
    Both should be set to 1.
  18. #38
    Jan 2005
    Its not that you try these parameters these are the parameters that you need to have set for your VFD and Spindle, this is the starting point
    If you have Mach3 correctly set and the PWM voltage is changing when you enter a different speed like M3S12000 in MDI this should give you around 5v if it does not then you have something wrong with your Mach3 setup or the Breakout Board
    Mactec54
  19. #39
    Sep 2005
    CNCRP has an extensive section on setting up Mach3 for a Spindle, if your using their control panel. Even If not using their panel, you should still be able to gather the information you need from their Website. Have you read and downloaded that information?
    1000x750 Workbee CNC - Mach4 - PMDX USB - Windows 10 Pro
  20. #40
    ericks
    Guest
    So......how are you going with getting your spindle sorted?
