New Machine Build DownUnder Machine Build .. Pro 60120 with Servos and other fun stuff - Page 5
Page 5 of 6 FirstFirst ... 23456 LastLast
Results 49 to 60 of 65
Thread: DownUnder Machine Build .. Pro 60120 with Servos and other fun stuff
  1. #49
    Apr 2017
    Default Re: DownUnder Machine Build .. Pro 60120 with Servos and other fun stuff
    Hi mate- where are you based? I went down to build it from scratch path and it has been a long and challenging slog & with hindsight I should have started with a decommissioned table or kit instead.
  2. #50
    Jan 2016
    Quote Originally Posted by Brood View Post
    The other end ! WA it was a long boat ride ..
  3. #51
    May 2017
    Hi Andrew, out of interest, which parts were missing?
    I have a very similar timetable to you with my order, I received into Fremantle last Monday. (48x96 PRO w NEMA 34 and Spindle)
  4. #52
    Jan 2016
    Hey elsy, great to hear you're also in Perth! We should get together some time.
    They left out my leg kit.. but they were great - the air expressed the missing alu (all 60+lbs of it) to me on Monday.
    Build is progressing .. but have hit a snag. Will see what CNCRP can do with the next challenge.
  5. #53
    Jan 2016
    Progress..
    Running in the spindle, machine pretty much built.. just one more thing !
    I forgot that I had upgraded from 4896 to 60120.. so . my cables for the servos were all too short ! 60120 needs a lot more cable!
    DMM DYN4 servos are really nice to setup and look forward to first cuts this week.
    Also connected up my camera to enable remote monitoring
    DownUnder Machine Build .. Pro 60120 with Servos and other fun stuff-56420688113__5e048223-ce63-477f-9624-bf1f463f5fb2-jpgDownUnder Machine Build .. Pro 60120 with Servos and other fun stuff-hqux9r-syi89qghs5kgna-jpg
    Attached Thumbnails Attached Thumbnails DownUnder Machine Build .. Pro 60120 with Servos and other fun stuff-56420688113__5e048223-ce63-477f-9624-bf1f463f5fb2-jpg   DownUnder Machine Build .. Pro 60120 with Servos and other fun stuff-hqux9r-syi89qghs5kgna-jpg
  6. #54
    Jan 2016
    Running at full 300Hz, I'm seeing the body of the CNC spindle reaching 50C.. about 20-25C over ambient.
    Wondering if this is what other people are seeing ?
  7. #55
    Jun 2017
    You making great progress
  8. #56
    Mar 2003
    I'd run it at half speed for an hour or two, to "break it in".
    You may see it run cooler after that.
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
  9. #57
    Jan 2016
    An update - after 2 days of soldering and splicing cables ( a task I will never do again !) I have got all 3 axes moving !!
    Now the gantry seems to be a bit twisted so will realign the plates tonight and am ready to start squaring and trammung the gantry and spindle !!
    Will have to order an extra set of 10m cables and upgrade the default cable drag chain to 130-150mm size as it wasn’t sized to carry AC servo and encoder cables.
  10. #58
    Jun 2017
    Quote Originally Posted by andrewwong2000 View Post
    Please post pics of the completed machine
  11. #59
    Jan 2016
    Here’s a good one .. was using a punch as a pointer to square the gantry
    My gcode wasn’t good
  12. #60
    Jan 2016
    First gcode test
