New Machine Build DownUnder Machine Build .. Pro 60120 with Servos and other fun stuff - Page 2
Page 2 of 6 FirstFirst 12345 ... LastLast
Results 13 to 24 of 65
Thread: DownUnder Machine Build .. Pro 60120 with Servos and other fun stuff
  1. #13
    Jan 2016
    Default Re: DownUnder Machine Build .. Pro 60120 with Servos and other fun stuff
    I’ll be really excited if it actually can mill some 6061 but I am fully aware it’s not a VMC ..
    If it can mill Jarrah and HDPE/Delrin I’ll be happy enough
  2. #14
    Jun 2017
    I guess that's why i decided not to buy one of their machines. I needed something very rigid to also do aluminium....hopefully my build will be a success
  3. #15
    Jan 2016
    Three machines needed 4axis wood router, metal mill and metal lathe.
  4. #16
    Jun 2017
    That's sounds good.....my next build will be a cnc mill....however i don't plan to mill metal, i don't mind aluminium chips but really don't like metal chips
  5. #17
    Jan 2016
    More progress
  6. #18
    Jun 2017
    Great job!!
  7. #19
    Jan 2016
    Had a bit of time today to get into the wiring.. this is going to take a few more weekends !
    The 24V systems power up and the interposing relays and contactors are working nicely.
    You can see the space left for the 5th Servo drive / Contactor / Relay .. if/when I go 4 Axis.
    DownUnder Machine Build .. Pro 60120 with Servos and other fun stuff-img_1171-jpg
    Attached Thumbnails Attached Thumbnails DownUnder Machine Build .. Pro 60120 with Servos and other fun stuff-img_1171-jpg
  8. #20
    Mar 2003
    Can you explain the purpose of that Crouzet device?
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
  9. #21
    Jan 2016
    I'm using it for :
    A - state machine for delay start & shut down of the servos based on e-stop , panel switches, charge pump
    B - send me email alerts if there are errors with servos, limits
    B is just a bonus from having ethernet on the PLC
  10. #22
    Jan 2016
    Did anyone spot my rookie Inelec wiring mistake ? I’ll give you a hint ...
    Sensor wiring !
  11. #23
    Jun 2017
    Please tell!
  12. #24
    Jan 2016
    Each sensor (prox switch) needs 24VDC and 0VDC but if you feed in the 24/0 as I have.. My set of 6 terminal blocks is short of space
    Here’s the power wiring pretty much done. Just have to bridge in the 3 phase split between VFD and this panel after the MCB on the top right, add wiring for fans and control switches.
    Tested a servo and drive unit.. success
