New Machine Build CNCRP Pro4x8
Page 1 of 2 12 LastLast
Results 1 to 12 of 18
Thread: CNCRP Pro4x8
    Registered pugsly's Avatar
    Jun 2015
    Default CNCRP Pro4x8
    I'm making the switch from a Tormach/Sieg KX3 mill to a CNCRP 4x8 router. I've decided that the bigger table is a better fit for my requirements compared to the precision and hard metal handling capabilities of the mill. Looking forward to the build process - my mill was a Chinese mess that took a lot of time to sort out, so I think I'm up to the task!
    Even thought I'm not sure about needing the size, I have room for a 4x8 and being able to put material on the router bed without trimming it down has a lot of appeal.
    Jun 2017
    Default Re: CNCRP Pro4x8
    Good luck with your build I ordered my 4x8 Pro last Monday. Did you purchase the Nema 24 or 34? Are you going to use a router or spindle?
    I'm going to build a vacuum table for mine, what are you going to use for material hold down?
    Enjoy
    Gary
    Jun 2015
    Quote Originally Posted by Gary-Wiant View Post
    Enjoy
    Gary
    Thanks!
    I haven't figured out what I am going to do with work holding yet, I will be starting out with screws and clamps. I went heavy duty - Nema 34 and the spindle. I plan on doing a lot of aluminum so figured beefier was better.
    Jun 2017
    Sounds great, I ordered the Nema 34 plug & play unit with CNCRP Sindle as well. I'll be doing a lot of sheet stock (aluminum, wood, pvc & acrylic)so I think a vacuum table will work best for us.
    Jun 2015
    Yep. At least having a CNC table should make building a vacuum table pretty easy.
    What are you thinking for the pump(s)?
    Jun 2017
    I ordered 4 of the 122178-18 from centralvacuummotor.com that dgage recommended. My issue now is finding a product to use as a plenum. I know I can use MDF but I hear it is a hassle to sell with epoxy, or I could use phenolic but I was quoted $780 for a 4x8 sheet of 3/4"...ugh now I'm learning towards using 3/4" or 1" Versatex PVC. I was told on another forum it will work but I'm waiting on a call back from the Versatex engineer. If it would down for 5 minutes here, I'd design my vacuum & plenum. Im planning on 4 2'x4' zones that I'll be able to turn on each motor & zone individually & I'd like to place T-Slots between the zones just for a alternative to the vacuum table.
    Plus i'm still 7 weeks out of mine being shipped
    Gary
  7. #7
    Jun 2015
    I should have (most) of mine coming sometime this week. I'm doing some product development work for a company right now, really looking forward to having the opportunity to do my own prototyping (they have an industrial grade 5x10 with ATC, etc).
  8. #8
    Jun 2017
    That sounds very interesting, I used to do a lot of that for Gerber Scientific (vinyl cutters & digital printers) back when they were actually coming out with new machines. I'm still on CadLink's Beta team to test their Signlab product.
    Thanks & good luck keep posting updates about your build.
  9. #9
    Jun 2015
    Day 1 of the build is finished. Everything has gone together pretty well.
    CNCRP Pro4x8-cncrp-pro4896-day-1-build-jpg
    Has anyone else had parts issues with CNCRP kits? One of the bolts was the wrong size, and one of the double t-nuts had only one of the two holes tapped. Not huge deals, but the whole point of buying the kit is not to have to modify stuff to make it work.
    Attached Thumbnails Attached Thumbnails CNCRP Pro4x8-cncrp-pro4896-day-1-build-jpg
  10. #10
    Mar 2003
    Call them and they should get you the right parts quickly.
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
  11. #11
    Jun 2017
    Looks good. Did you print the instruction manual or are you just using a tablet & going through it that way?
    I'm excited I received an email that my router has been partially shipped.
  12. #12
    Jun 2015
    I couldn't bring myself to print the instruction manual and kill that many trees. I'm using a tablet, which has worked well - if I want to zoom in on an illustration to see detail, etc, I can get a much better view than if I had printed it.
CNCRP Pro4x8
CNCRP Pro4x8
