Mach3 Windows 10 64bit 1803 Provisional Patch - Page 4
Page 4 of 4 FirstFirst 1234
Results 37 to 42 of 42
Thread: Mach3 Windows 10 64bit 1803 Provisional Patch
  1. #37
    Jul 2003
    Holmen, WI
    Default Re: Mach3 Windows 10 64bit 1803 Provisional Patch
    I do all the time. Never had one issue. (I also like to keep my os up to date). (I am experienced )
    Quote Originally Posted by RCaffin View Post
    And the worst part is that it is all YOUR fault. YOUR fault.
    Experienced CNC owners NEVER leave their CNC machine connected to the internet, for precisely this reason. We know this happens.
    YOUR fault.
    Cheers
    Roger
  2. #38
    Jun 2010
    I too have an IT background - back to the start of the 70s. But I have never met any other company which so ignores the customer's wishes as MS. But then, who else writes such awful SW?
    My design PC is connected to the internet, with all updates turned off (how to avoid having W10 stuffed down your throat), but the PC running my CNC is NOT connected. Both are actually W7, and they will stay that way. File transfer between the two is via USB-net, and it is not problem at all. The USB key usually lives in my pocket anyhow.
    Cheers
    Roger
  3. #39
    Mar 2003
    Shelby Township
    The latest version of Windows 10 Pro has added more options on their Update page. There's now a setting to "pause" updates for 35 days. But there's no way to stop them.
    So I'd consider setting the Pause, and every 30 days or so manually update yourself, so you don't get any surprises.
    If you want to completely stop updates, stop using Windows.
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
  4. #40
    Jun 2010
    If you are using Mach3, you have ONLY got Windows.
    All is solved by removing the internet connection.
    Cheers
    Roger
  5. #41
    Jun 2005
    Instead of removing the internet connection (physically), you can:-
    1. use a fixed IP address for the CNC PC without DEFAULT GATEWAY.
    In that way you can still transfer files between PCs via the network.
    2. Disable windows update by disabling the Windows update service and ALSO disable an entry in scheduled task put in by Microsoft to enable back windows update when you login.
  6. #42
    Jun 2010
    It is not clear whether ALL Microsoft SW honours that off-switch, especially with W10.
    Cheers
    Roger
