New Pro4x8 with dual z. gmt spindle and s30 atc spindle - Page 2
Page 2 of 2 FirstFirst 12
Results 13 to 20 of 20
Thread: New Pro4x8 with dual z. gmt spindle and s30 atc spindle
  1. #13
    Sep 2005
    Default Re: New Pro4x8 with dual z. gmt spindle and s30 atc spindle
    Quote Originally Posted by superscaryco View Post
    I have a crp850 from cncrouterparts. I cant say enough positive things about cncrouterparts. By far hands down been absolutely best to deal with. Ive been involved with frog 360 laguna biesse axyz weihong and fgp systems. cncrouterparts hands down by far best service no bull****.
    I know, I know. I have nothing but good service to report from these folks. So are you running Mach4 or Mach3 with your ATC?
    Retired Master Electrician, HVAC/R Commercial. FLA Saturn 2 4x4 CNC Router
  2. #14
    Activation process Aerojunkie's Avatar
    Aug 2018
    I have the S30 working but I only have one spindle and I am running the CRP800 electronics. On the smooth stepper all I had to do was move one wire, Im just not sure its the same wire on yours. I believe it was connecting the spindle over temp sensor wire to the 5v output 1. I would call or email Alex to confirm this first as I am unsure on your version. I also believe CNCRP is working on atc electronics, they may also be able to help you with the switchover. If I understand correctly that wire is used to trigger the solenoid for the tool change. CNCRP and Alex were both very willing to help me get going on mine. I can get some pics of my version if you would like.
  3. #15
    Sep 2005
    Running Mach3, correct? I do not have a ATC I was just wondering.
  4. #16
    Feb 2016
    Would love to see some pics. Im super swamped this week, I took on as much film projects as I could. I want to drum cash up for the hypertherm xpr800 asap to add to my machine. But am working on a post with every step of the way soon! I did get the macro going btw
  5. #17
    Feb 2016
    Mach3 yes. too far down the learning hole to jump to mach4 for no reason so far
  6. #18
    Feb 2016
    I also wanted to update incase someone else is searching. the s30 push connectors for air are 6mm outer dimension.
  7. #19
    Aug 2018
    No problem, I will get you a few in the morning. Right now my router is my 2nd job/hobby. I don't get near as much time in my shop as I would like.
  8. #20
    Jul 2017
    So heres the scoop. Im frank and passionate. so lets get 2 things out of the way....
    **** If you have a CNCrouterparts setup then dont do what I did.
    Buy their controller box ship it to s30 nashville office have them ship it with spindle back to you.
    Its a year and I finally got this ***** turning and connected to mach3.
    I'm not sure I understand this. Are you saying that we should not ship our CNCRP Electronics package to them to have them set up for the s30, or to buy the whole setup from them for the s30 and throw away the CNCRP package?
