CRP800 + MACH3 + J Tech LASER - Page 3
Page 3 of 3 FirstFirst 123
Results 25 to 31 of 31
Thread: CRP800 + MACH3 + J Tech LASER
  1. #25
    Jul 2017
    Default Re: CRP800 + MACH3 + J Tech LASER
    Quote Originally Posted by GigaWatt View Post
    I know this is an old thread however I'm ready to add a laser to my Pro4824 and have some questions for the posters that already have this setup. I'm considering using either the J Tech 2.0 or 2.8. I will use it mainly for engraving on wood however I would also like the ability to cut thin wood like 1/4" pine, plywood & hardboard.
    1. How are your setups working any changes?
    2. Is the 2 watt laser adequate for most work or should I go with 2.8?
    3. Do you have any additional comments that would help in installation, setup or use?
    I'm about to add my new 2.8w to my Pro4824 as well, but I'm still working out the details. I think I have the right connectors and parts and hope to have some time soon to put it together.
  2. #26
    May 2011
    Hi, Can anyone share pictures of how you mounted the J Tech laser to your CNC? Thank you!
  3. #27
    Registered dharmic's Avatar
    May 2015
    Not a j-tech or CRP-800 but you get the idea. A clamp around the bottom of the spindle, off to one side another clamp for the laser. I 3D printed mine but if you don't have access to one there's no reason you couldn't use the CNC to carve the same kind of thing out of an HDPE chopping board from the two dollar shop.
    Attached Thumbnails Attached Thumbnails CRP800 + MACH3 + J Tech LASER-img_2622-jpg
  4. #28
    May 2011
    Excellent, thank you.
  5. #29
    Aug 2011
    Hey Cstmwrks, could you send me your Mach3 XML? I have the PicConvert and its giving me some issues and I would like to compare settings.
  6. #30
    Jul 2014
    excellent post ty
  7. #31
    Registered ubergeekseven's Avatar
    Mar 2017
    Nice
