It seems with the router setup in this configuration, I only get 22.25" of usable table in the X axis. Now this really isn't a problem for me. It might be a surprise for some. My production blanks are 16" by 48". To get the full work area, I would have to slide the table this way and either add another extrusion to the front and two small ones on the back or use a few of the brackets like I used under the bed. I can surface the entire 2' x 4' spoil board with this bit though.
Since I don't actually need the extra travels, I think I will optimize it at 22.25". Cut the spoil boards to that size and go with it. I still have the larger plasma cutter than I can route out larger stuff with if needed. Like the Tormach lathe, I will optimize it for our production.
The new spindle is probably one reason some of the table space is lost. It has a double plate mounting system, however it has an eccentric tram aid designed in. Sweet spindle too, so I am cool with that trade off for space.
I will lubricate the racks and square up the gantry.. Then set out to surface it.
Gwizard tells me my spindle will not go slow enough. This is a 1.5" 2 flute surfacing bit or face mill. I plan on a .01" DOC @ 50% step over and go about 60 IPM. 10 degree ramp. 8000 RPM. I couldn't find a Manufacturer suggested surface speed or chip load. GW says this is a .003" chip load.
I'll search around to see if I can find a similar tool with factory recommendations.
