Need Help! Z-axis gaining height with no command
Results 1 to 2 of 2
Thread: Z-axis gaining height with no command
    Member SolemnSentinel's Avatar
    Dec 2023
    Default Z-axis gaining height with no command
    Hey guys, I have a Premier Plasma 2x4 table, run off a Dell PC with Mach 3. All hardware was provided by Premier. The problem I'm having is the Z-axis, with the program running, is running about a quarter inch (6MM) high above the displayed value. In manual mode it is working perfectly, I can run the torch all the way up then down and it will read approximately zero when touching the work piece. There has been no change in software, I use the provided Sheetcam TNG. I did have to replace the UC100 micro USB to 25-pin connector as the USB socket came loose, but not sure why that would only affect the Z-axis while it is running a program. Any help would be appreciated.
    Here is a code section from a part:
    N0010 (Filename: Coal scoop.tap)
    N0020 (Post processor: PREMIER PLASMA post processor SHEETCAM 2021.scpost)
    N0030 (Date: 23/12/2023)
    N0040 G20 (Units: Inches)
    N0050 G53 G90 G40
    N0060 F1
    N0070 S500
    N0080 (Part: Coal scoop)
    N0090 (Process: No Offset, 0, T5: 14g)
    N0100 M06 T5 (14g)
    N0110 G00 X15.6339 Y3.9961 Z0.3937
    N0120 G31 Z -100 F19.685
    N0130 G92 Z-0.28
    N0140 G00 Z0.1181
    N0150 M03
    N0160 G01 X15.6339 Y3.9961 Z0.0591 F50
    N0170 F140
    N0180 X16.1339
    N0190 M05
    N0200 G00 Z0.3937
    N0210 X17.1339
    N0220 Z0.1181
    N0230 M03
    N0240 G01 Z0.0591 F50
    N0250 F140
    N0260 X17.6339
    N0270 M05
    N0280 G00 Z0.3937
    N0290 X18.6339
    N0300 Z0.1181
    Dec 2023
    Default Re: Z-axis gaining height with no command
    Also to clarify, it does not gain height as it goes, it sets to a new height while displaying the value of what it should be at, like it has reset the zero.
