- Deckel Maho DMU60 P
Re: Deckel Maho DMU60 P
Can U show the programm? Looks like u want to move more than machine can.
Hey steryd!
In general, in my offer to buy the machine is considered a 5-axis simultaneous machining center
equipped with ITC & chip conveyor. But for some reason I cannot turn the spindle using the code
in a position between horizontal and vertical.
The code I tried to rotate the spindle looks like this:
N1 M55
N2 G7 B5=30 L1=2 (So it is written in the manual for my machine)
But after writing this code, I get an X31 error.
I can turn the spindle to horizontal/vertical position using M53/M54 commands.
Also in diagnostic mode, I can rotate the spindle to a position between vertical and horizontal,
and clamp the spindle in these positions.
Perhaps I am mistaken in the code, or maybe my machine does not really have such a function.
If you have any advice, I'd be happy to read it.
In any case, thanks for the help!
- You may not post replies
- You may not edit your posts
Forum Rules
