- ENSHU 610 toolchanger hanging
Hi All,
I'm trying to get this machine running after it has set for about a year.
All seems to work well except the toolchanger, the arm hangs at midpoint in the cycle and i get an alarm that says that LS14 is not active,
I have found the switch behind the chain and its not very accessible. it looks like the easiest way to get to it would be to remove a couple of pots from the chain.
Does anyone know how to do this?
Thanks,
Walt
- You may not post replies
- You may not edit your posts
Forum Rules
