Need Help- swivel head parameter? Endpoint beyond SW limit switch
Results 1 to 1 of 1
Thread: Need Help- swivel head parameter? Endpoint beyond SW limit switch
    Default Need Help- swivel head parameter? Endpoint beyond SW limit switch
    Hello Everyone, I have one DMG DMU60 monoblock, control is Millplus 3DIT
    and I am turning the swivel head (B axis) the range should be -120/+30 degree, but I only swivel around 30 degree, than show up two alarm message, I think it’s parameter mistake, who can tell me which parameter I need correct? and the correct value of parameter? Thank you.
    Need Help- swivel head parameter? Endpoint beyond SW limit switch-123770262_1673394372821239_1122036916830951453_n-jpgNeed Help- swivel head parameter? Endpoint beyond SW limit switch-124020378_1673394366154573_7531690810356291496_n-jpg
    Attached Thumbnails Attached Thumbnails Need Help- swivel head parameter? Endpoint beyond SW limit switch-123770262_1673394372821239_1122036916830951453_n-jpg   Need Help- swivel head parameter? Endpoint beyond SW limit switch-124020378_1673394366154573_7531690810356291496_n-jpg
