Belt and Chain Tension
Results 1 to 3 of 3
Thread: Belt and Chain Tension
    Dec 2006
    India
    Default Belt and Chain Tension
    Dear Experts
    As u r aware, in case of machining centers, it takes lot of time to open the covers to check belt and chain tension say in case of ATC Magazine & restore
    Was wondering if there is any other better way of doing this at less time
    Kindly suggest
    Regards
    Member deadlykitten's Avatar
    Jun 2015
    Antarctica
    Default Re: Belt and Chain Tension
    hy rishikesh some panels arround here have been removed from the machines, or modified in order to put them fast on / take them down fast ( by leaving the screws where they are ), allowing easier acces to lathe spindle & tailstock, mill spindle belts & atc, etc
    pls check modification in attachment; sorry for the rough sketch / kindly
    Attached Thumbnails Attached Thumbnails Belt and Chain Tension-untitled-png
    we are merely at the start of " Internet of Things / Industrial Revolution 4.0 " era : a mix of AI, plastics, human estrangement, powerful non-state actors ...
    Dec 2006
    India
    Thanks for your prompt response
