- Drum Filter - blockage
Dear Experts
As you are all aware, drum filter is used in most of the machines and in case it got clogged & not cleaned as per the predefined schedule, we get huge coolant leakage
Kindly revert if it is possible to provide a proximity switch etc over drum filter to sense if filter got clogged and there by stop the system to stop overflow and leakage
Regards
- You may not post replies
- You may not edit your posts
Forum Rules
