- Mikron WF 40 C RS232 connection to laptop via Winpicin
As the title sugests, we've been trying to connect that machine to laptop with winpicin program, we've bought schematic for cable 9 pin to 25 pin soldering and settings for setting up connection but weren't able to put any data through cable, not a single bit of data transfer was done, although the connection was recognized on winpicin also on machine because there was time limit error when you press receive on laptop and data does not go through cable from machine...
Does anyone have a clue what could be the problem and how to fix it?
Also, is it possible to program using variables on that machine?
thanks in advance!
- You may not post replies
- You may not edit your posts
Forum Rules
