Morbidelli N100 - need Help
Results 1 to 2 of 2
Thread: Morbidelli N100 - need Help
    Member vondrous's Avatar
    Nov 2023
    Default Morbidelli N100 - need Help
    Hello
    Ihave a problem with start machine. the remote control does not communicate with the machine. Only Windows starts in the driver and that's it. The application for controlling the machine does not start. Probably some SW error. The service told me that the entire controller must be replaced. Has anyone had the same problem? Thank you very much for any help
    Attached Thumbnails Attached Thumbnails Morbidelli N100 - need Help-img_1635-jpg
    Member ducarley's Avatar
    Nov 2023
    Default Re: Morbidelli N100 - need Help
    I have 3 controllers from Morbidelli and SCM who use the same. However these are older PLC that use Kletra from ESA if that would work for you
