- Morbidelli Author 636 Axis Drive Fault
Is there any alarm on yaskawa driver?
Re: Morbidelli Author 636 Axis Drive Fault
I found the drivers, look, but I don't an alarm code or something
Hey looking for someone that has switched out a Richauto controller to a NVCMV2.1 Mach 3 controller 6 aixs
The plc faults are probably due to the first X axis servo fault.
That's where you should start. Check the drive for error codes.
- You may not post replies
- You may not edit your posts
Forum Rules
