NewCnc-No Movement
Results 1 to 4 of 4
Thread: NewCnc-No Movement
    Member CwoodA's Avatar
    Mar 2021
    Default NewCnc-No Movement
    I purchased and moved across town a NewCnc router which was running at the time. It sat for about 18 months before I got around to getting it back up an running. Now that I have it powered back up Mach3 reporting an overtravel on my Y axis but the spindle is sitting in the center of the table (off any switches), my Yaskawa servo amplifiers are all showing Pot/not error, and my servo motor contactors are not engaging so I am dead in the water for now. Tested all overlimit switches and they are good. Tried disabling overtravel in pins and ports with no change. Any ideas on where to look next?
    Member coc9's Avatar
    Jul 2018
    Default Re: NewCnc-No Movement
    Hello, check the 24v supply line, it should be clear. Pot/not error is an over travel error so if the axis are actually not at over travel position then you may reset the errors in yaskawa drives.
    Mar 2021
    I found out what the issue was!
    I had an electrician come by who happened to be familiar with the DirectLogic6 PLC's my router uses. He just switched the toggle from Terminal to Run and then back to Terminal. He said this causes the PLC to reset and bam, my servo contactors engaged, the pot not errors switched to run on my servo drives and I am up and running.
    Member routalot's Avatar
    Dec 2003
    I hope you have a productive time with your newly functioning machine-thanks for leaving the information here so others can access it.
NewCnc-No Movement
NewCnc-No Movement
